Re: Surging Governor A
Posted by Red Dave on August 25, 2007 at 16:00:31 from (68.44.136.10):
In Reply to: Re: Surging Governor A posted by Kendog on August 25, 2007 at 15:26:06:
If I remember right, there is a spring on the end of that adjustment screw. Yours may be worn or broken if you are that far out of adjustment.
It is not that hard to remove and rebuild/repair the governor, but you must have a repair manual and a parts diagram and you must not remove the gear that drives it from the housing or it will get out of time. Take your time and replace all the springs and anything else that is worn or broken inside. Your Case/IH dealer still can get the parts.
