Re: Replacing M Hydraulic Cylinder ?
Posted by Brownie450 on August 26, 2007 at 05:19:02 from (207.177.82.141):
In Reply to: Replacing M Hydraulic Cylinder ? posted by FarmAll-or-Nothing on August 26, 2007 at 04:01:19:
These cylinders are not hard to work with. There are 4 or 5 V-packings in the nose & the brass bushing-- if not available from IH, is a standard size or able to be turned by someone with a lathe. On the lower end, there is a cup leather which usually is bad, & a thin paper gasket to seal both ends to the cylinder tube. The last stuff we got from IH was 10 years ago. Worth a try at IH.
