Re: 140 xmission oil leaking from axle housing-advice?
Posted by NawlensGator on August 26, 2007 at 10:22:21 from (74.230.199.83):
In Reply to: Re: 140 xmission oil leaking from axle housing-advice? posted by Patrick Martin on August 24, 2007 at 17:30:53:
Just got back from a trip and read your replys. If the level plug is the one with the 5/16" socket just below the brake rod (left side), then there is way too much oil in there. Today I will drain it all out and put in 5 1/2 qts of gear lube. I won't even mess with the level plug because it looks like I'd have to disconnect the brake rod. If that works you guys have saved me a load of work. Thanks a lot!
