Re: Farmall B idling HIGH
Posted by CityBoy-McCoy on August 26, 2007 at 13:01:28 from (65.0.156.135):
In Reply to: Farmall B idling HIGH posted by davset on August 26, 2007 at 12:38:53:
Maybe. But, maybe it is running lean, which would make it rev up. Crank it up and when it starts to rev up, pull the choke (gradually) part way out. If the rpms level off and it runs smooth, I'd be more suspicious of a lean condition. If lean, either the carb is not as clean as you had hoped, fuel flow is restricted, carb needs adjusting, or you have an air leak at the carb or manifold to head seal.
If partial choking has no effect on idle speed or if it runs rough with partial choke, I'd say then go after the governor. mike
