Farmall B idling HIGH
Posted by davset on August 26, 2007 at 12:38:53 from (97.81.193.158):
Well, I got my "45 B cranked today for the first time since I got it home two weeks ago (after cleaning the (M-S) carb (It was pretty gummed up), gas tank, changing oil, plugs, etc.) ((It had been setting at the previous location for at least 3 years, so I don"t know when the last time it ran.)) I"ve got lots to do on her yet, but she"s in pretty good shape already - I just gotta get her running good.
When I pushed the start lever this afternoon, she fired right up, but immediately rev"d up high. Finally got it to run pretty good with hand lever at absolute minimum (the min idle adj on carb had some small effect) but the governor still wants to creep up slowly. I can pull the governor linkage by hand to close the carb throttle and it will run OK for several minutes, then slowly creep back up. But when the hand lever is at anything other than absolute minimum, engine speed is excessive.
I"m thinking I should pull the governor and clean it. What do y"all think?
