Re: Farmall A trans axel fluid
Posted by Red Dave on August 26, 2007 at 15:10:47 from (68.44.136.10):
In Reply to: Farmall A trans axel fluid posted by Al Barneson on August 26, 2007 at 14:48:16:
80-90 gear oil is fine, as is 80-140 gear oil.
There is a small pipe plug on the left hand side of the transmission, behind the rod for the left side brake. That is the full line. Put it in the top until it comes out that hole.
If it has a PTO, there is an extra drain under it to get some old oil out of. Put a cup or so back in the PTO before you fill the transmission.
