Farmall A trans axel fluid
Posted by Al Barneson on August 26, 2007 at 14:48:16 from (69.4.104.253):
I have a 1939 Farmall A that I just drained the fluid from the gear case.It was milky so I figured it to have accumulated moisture over time.I was wondering what I should replace it with and how much it holds.I took out approximately 12 quarts.My son said 80-90 gear lube should work which I think makes sense.I just got through doing the Farmall 560 and used trans hydraulic fluid as it has a hydraulic pump.What I am not sure of is how full to fill it?Or the type of fluid.
