Re: not sure where to post this question
Posted by Heat Houser on August 26, 2007 at 18:47:17 from (69.66.35.73):
In Reply to: not sure where to post this question posted by tn terry t on August 26, 2007 at 18:36:26:
Area of the circle times length equals volume.
Area of a circle is pi(radius squared)
Since you have diameter, 1/2 is the radius.
31 divided by 2 equals 15.5 in
15.5 times 15.5 times 3.1416 equals 754.77 square inches.
754.77 times 56 equals 42,267.12 cubic inches.
There is 231 cubic inches per gallon.
42,267.12 divided by 231 equals 182.97 gallons.
