How do I remove the seal that leak on my H
Posted by dave westlund on August 26, 2007 at 19:36:25 from (207.67.7.2):
I have an leaky oil seals from shaft that goes from the belly pump to the rear end. I removed the coupling that connects the hydraulic pump to the rear end and it looks like I need to remove a threaded end from the hydraulic pump as well as the rear end to replace the seals. Can replacing the seal on th epump be done with out removing the belly pump? Are either of these pieces I need to reove Left handed threaded? I would appreciate our help with this.
Thanks dave
