Re: How do I remove the seal that leak on my H
Posted by Nebraska Kirk on August 26, 2007 at 20:18:30 from (207.91.30.78):
In Reply to: How do I remove the seal that leak on my H posted by dave westlund on August 26, 2007 at 19:36:25:
They are both right hand thread. If you can get that piece unscrewed without removing the pump you are doing good! It is probably pretty tight, you can try sticking a square shaft into the notch and whacking the bar with a hammer, you may be able to jar it loose.
