IH tractor identity w/ case model 33 ck backhoe
Posted by bc on August 26, 2007 at 23:41:39 from (71.158.215.82):
Hi, just got a used IH tractor with a model 33 CK backhoe w/ serial # 4195858 and also has a loader. The hoe may not be original. The id plate is gone. It appears it may be a 560 or similar model. It has a gas engine. It won't stay running so I pulled the carb. It is a 1 & 3/8" throat so I believe it is a c-263 engine from this generic shop manual that came with it. It takes a wix 51158 oil filter (spin on type) It has a forward and reverse lever as well as a gear shift. The engine casting number is 379815R1 and the tranny casting number is 370472R4. It has a plate bolted over the pto shaft area.
Can anyone ID this tractor model and year built? It doesn't seem logical for a 560 to have a hoe hooked to it. Thanks.
