Re: Need help with M wiring
Posted by John S-B on August 27, 2007 at 11:20:03 from (64.12.116.73):
In Reply to: Need help with M wiring posted by John S-B on August 27, 2007 at 11:16:11:
I should have given a better indication of the wire, it's the black one on the far left. Also does the coiled wire (resistor?) in the bottom center need to be replaced? I could'nt tell if it had some kind of white coating or if it was corrosion.
