super 'C ' HYD Woos'
Posted by Larry in GA. on August 27, 2007 at 17:56:24 from (71.31.253.82):
Thanks for the help earlier and you are right Brad Marshall Is a great help but we are still having a problem coming up with a good drive shaft for a 355007R92 pump. Brad is still looking and I appreciate the time he is spending.
But I was wondering did I read on here that there is a speedy sleeve available for this shaft?
Or does someone out there have a good shaft?
Thanks
Larry
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
