Posted by Grabatire on August 27, 2007 at 20:24:59 from (216.95.83.183):
In Reply to: WD 9 posted by Gordon Vincent on August 27, 2007 at 07:30:51:
I know of a chap who has a SWD9 running at 1750 to 1800. He cheated a bit though. What he did was take an engine from a TD9-91 which has a counterbalancer for the crank. The 91 normally runs at 1650 I believe, so he has it rev'd up a bit over spec. He still uses the origional injection pump though but has it turned up a bit too. It sure pulls good and man does it ever smoke when it gets to serious pulling.
The IH type A single plunger injection pump is the same for the 6's, 9's and 14's except for the plunger which is larger for each model. The drive gear needs to be changed to suit the application but the pump body will fit on either model. There is also a difference in the scavange/transfer pump depending on the year of mfg.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
