Farmall H flywheel
Posted by Travis Tietjen on August 27, 2007 at 21:10:49 from (24.111.253.222):
I inheritd an H with a bad flywheel. The tractor runs like a top if you give it a pull but you cannot start it with the starter because the flywheel is all ground off.I belive you have to split the tractor to fix this correct? and if so can anybody tell me from experence the best and easiest way to do this. Thanks, Travis
