53 super A
Posted by Rob Baird on August 28, 2007 at 19:41:56 from (71.203.89.100):
I finally have it home almost 1700 miles later.
Fixed all ythe trailer lights greased wheel bearings had some welds checked on trailer.
Had the tread blow off a trailer tire in Tenn. so wound up with 4 new tires. Finally have tractor at home so decided to clean it some and pressure washed it. Then it would not run right. Cleaned out carb that helped some. Then cleaned out Dist. cap that helped new plugs and cleaning all connections that really helped. Now it is running well. Ring gear is bad and starter bendix is bad.
How is best to fix that. I have parts manual and owners manual. What is best for a shop manual.
Rims are good, no block cracks,steering is tight,
shifter seems to have a lot of play Any ideas why?
I mowed the grass Monday night with it did a nice job. It has been converted to 12 volt
sorry so long
