Plain Glazed or Cream Filled?
Posted by A. Bohemian on August 29, 2007 at 07:15:20 from (207.170.88.70):
In Reply to: Re: am trying to get a 42 model H to run posted by Mike CA on August 28, 2007 at 21:55:24:
Sorry, Mike. Couldn't resist.
Do the fuel flow test, as others have described. Remember, a STEADY stream roughly the size of the plug, for several minutes.
After encountering trouble, did you clean out the sediment bowl and examine the contents?
If you did, why didn't you tell us what you saw? If you didn't, why not do it now and let us know?
As Dell says, we all flunked mind-reading.
