Posted by Owen Aaland on August 30, 2007 at 06:40:00 from (65.161.86.86):
In Reply to: just for fun posted by bm3501466 on August 29, 2007 at 20:15:03:
Best would be to put it in the M. The H has an 18 inch wide frame and the 460, although it has the 20 wide frame, narrows down to fit the same clutch housing bolt patern as the H. The M has the 20 inch frame width that was carried over to the 706 and larger tractors. Use the back plate from a tractor that has the 400 series engine. If you use the truck engine front plate just use the M frames. If you switch to a tractor front cover using the later frames will be easier.
I don't know about the flywheel. 400 series flywheels were available with both a 12 inch (same size as a super M) or a 14 inch clutch. How the OD will fit in the clutch housing or what it will take for a starter someone else will probably know.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
