Re: 560 vs 660 differential housings
Posted by Wardner on August 30, 2007 at 15:09:56 from (4.154.245.160):
In Reply to: 560 vs 660 differential housings posted by BigART on August 30, 2007 at 08:01:30:
third party image
I took this picture the other day as I got a flat and used the opportunity to put one of my wheel weights on the inside. Not looking forward to doing the other side
The International 560 and 660 differences are few. The 660 radiator is three inches higher and that affects the "dog legs". Extension are spot welded to the bottom of the 560 legs. The fan moves up to 6 blades from 5. A cast iron spacer is fitted below the front of the grill. From the axle housings to the rear tires, everything is different. I have just listed all the differences with the exception of the badges.
The engines are identical and that includes the pump and injectors. The 660 is adjusted for 600 more rpm.
