Someone stop me if I am wrong, but I think there is only 3 bronze bushings in the entire rear end. 2 on the reverse idler gear and one in the end of the lower trans shaft for the PTO. There are two bushings for the brake band pivots, but they are sealed off from the rear end. I would have to say the High GL rating is most likely shear additives for high load applications and I think they use sulpher for that. If you let water get in the rear end from sitting outside or washing the tractor a lot, it could cause sulphuric acid to form and eat the bronze. My H manual does say to change the gear oil once a year. When they were new, some gear oils acually had lead in them for high friction protection. Lead is one of the best friction additives there is, but the gov had their way with that way before the EPA existed. I do know where about 20, 1 gallon square metal cans of that old stuff with the lead is sitting, but you have to buy the ring and pinion/differential assemblys to get them and they fit early-mid 50s buicks.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
