Posted by Paul Shuler on August 30, 2007 at 16:02:36 from (170.29.248.3):
There was a discussion a few days ago about gear oil in old Farmalls. It talked about GL-1 through GL-5 90w oil. In my ignorance I didn't even know there was different grades of 90w. This morning I went out to look at the bucket of gear oil I used to top off my H when I changed the pto seal. I Added about two gallons. It said rated GL-5 through GL-3. In the previous discussion it came out that some felt the GL-5 stuff was over kill for old tractors and that it may even be harmful to brass bushings. If this is the case do I need to drain and flush my rearend{on the tractor}. Oil is high now but would be cheaper than a rebuild if it screws something up. Tractor is used 15 to 20 hours a month mowing. All opinions welcomed. Thanks Paul
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
