Hi Paul - I agree with dcw (below). For your H as long you used grade of oil, it's GL classification probably doesn't really matter.
And even if the GL 3 - 5 DOES cause corrosion or wear on certain parts (which isn't certain...), it'll take place much slower than it did with the original mixture of oil, water and whatever else you drained out of the rear end before.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
