Re: Factory fast hitch vs. aftermarket 3-pt
Posted by BOBM25 on August 31, 2007 at 08:42:55 from (69.68.42.16):
In Reply to: Factory fast hitch vs. aftermarket 3-pt posted by K.B.-826 on August 30, 2007 at 17:42:47:
I myself would go with the fast hitch. I haven't seen an aftermarket 3pt setup that I really "liked". They all look like they will work for most stuff, but none are as heavy as I think they should be. The Saginaw one looks pretty good, but kinda pricey I think. With a little work a worn out fast hitch can be fixed up pretty well actually, especially if you have access some metal working equipment. I realize that not every one does though. The good thing about a fast hitch, in my opinion, is you have some draft control for plowing or ground working implements. Not real good draft control, but some draft control. At the local auctions around here fast hitch stuff usually goes pretty cheap because no one can, or doesn't want to, use it anymore.
