Re: Running with the choke out
Posted by El Toro on August 31, 2007 at 19:31:03 from (205.188.116.73):
In Reply to: Running with the choke out posted by Larry in GA. on August 31, 2007 at 17:09:43:
Good indication of a lean carburetor. Need to
check the fuel system from the tank to carburetor.
Pull the gas line off at the carburetor and check for a good flow no dribble. Hold a clean container under the gas line and if there's a good stream check the strainer at the carburetor inlet. If its clean you need to pull the carburetor and soak in carburetor cleaner and blow out all passages. Then install a new kit. Hal
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
