Running with the choke out
Posted by Larry in GA. on August 31, 2007 at 17:09:43 from (162.40.232.6):
The Super C has started running real rough unless you run it with the choke out about 1/3 to half way. You can pull the choke out tell it smoothes out and run it all after noon jest fine.Try pushing it back in and it goes to running rough again. I have started leave it out and it starts right up and runs at that setting. Any ideas would be appreciated.
Larry
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
