Re: Running with the choke out
Posted by crate78 on August 31, 2007 at 21:21:04 from (199.184.119.22):
In Reply to: Running with the choke out posted by Larry in GA. on August 31, 2007 at 17:09:43:
Excess wear on the butterfly shaft in the carb can cause it to pull air in past the shaft resulting in a lean condition. We had this happen on a VAC Case once.
Since the carb body is cast and the butterfly shaft is usually brass, the shaft will usually wear instead of the carb body.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
