We had that with out skid steer. It was a combination of things in our case. Its definatly lean. But first several things can cause that. ANY way extra air goes in that the carb doesnt intend (by design) will lean it out. And if it runs with choke on that far its got a nice leak somwhere. Bad carb body gasket, cracked manifold, loose manifold or stripped/broken bolt etc etc. Check the entire system from block up is my recomendation cause anywhere along that entire intake system can be a issue. Old iron often cracks under stress. Metal gaskets deteriate etc. In our case it was cracked manifold, loose bolt (as a result), and ALL bad gaskets some leaking more then others. Gaskets are cheap. Best to replace them and rebuild or atleast clean carb and set float height (also check float for squareness to carb body).
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati
... [Read Article]
Latest Ad:
[More Ads]
