TA problems help
Posted by James3504 on September 01, 2007 at 19:36:32 from (70.109.4.190):
I recently bought a 450. When you pull the TA, it works briefly and then you hear a spinning noise. Is it busted, worn out or out of adjustment. I'm new to TA's and know nothing about them. Any help would be great. I don't know how to adjust or determine what's wrong. Maybe some of you guy's could help me out with some info. Thanks!
