Posted by TominKy on September 01, 2007 at 19:54:21 from (207.162.163.20):
In Reply to: 460 Power steering posted by pondman on September 01, 2007 at 18:03:49:
Go to oldoakfarmalls.com/Hydraulics. There is an extensive article about 560 hydraulics ( 460 is the same ). although you didn't specify, I assume that you have a Farmall( mine is an international(utility model)) and the site will be specific to your tractor. On my International the clutch pedal was in the way, otherwise it was an easy job. The Power steering pump is mounted on the same plate as the hydraulic pump and the whole thing slides out like a file drawer, and goes back the same way. The pump intake slides onto a suction pipe and then all that remains is to slide it completely back in and replace the bolts, new hydraulic fluid, and filter and you're good to go.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
