Fuel consumption on a C-264
Posted by Wardner on September 02, 2007 at 00:09:43 from (4.154.246.192):
I don't know if IH ever published graphs on pounds of fuel per hour per HP.
Anyone care to guess what a C-264 would use running at about 900 RPM and meeting the continuous full load needs of a 10,000W generator? I am assuming that power level will require less than 20HP and be available at 900 RPM.
Let's not talk about PTO gear ratios. The generator will be run at 60 cycles per second using the proper pullies.
