Re: Raditor removal, the next step
Posted by Larry806 on September 02, 2007 at 13:29:20 from (74.218.14.82):
In Reply to: Raditor removal, the next step posted by Mike CA on September 02, 2007 at 13:10:57:
Just got done removing a radiator on a SMD . Take the steering shaft apart back at the u joint . Use a 9/16 wrench to take the bolt out . Than turn the steering to " screw " the worm gear out the front . You will have to tap it some to get the shaft to come out of the u joint . As it comes out you have to remove the woodruff key so the shaft will go through the hole . Leave everything together in the front . It will come out in one piece just fine . Clear as mud?
That being said I would leave that bolt alone for now . If it is a bottom bolt you will have to take it to a rad . shop to get it fixed if I'm thinking right .
