Hal: That doesn't work after 1954. The 100 and 200 each had their own sequence of serial numbers each starting at 501. The C-123 engines used in both tractors had a common sequence of engine serial numbers.
This carried on into the 130 and 230, tractor serial numbers of each started again at 501, however the C-123 engine continued from the last 100 or 200 engine. It happened again with 140 and 240, each started at 501 tractor serial number, however the engine serial number continued from last 130 or 230. Casting date codes will be as close as he will come on a 200.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
