Re: IH 384 Starved of fuel
Posted by FromJB2 on September 02, 2007 at 16:53:30 from (74.111.119.222):
In Reply to: IH 384 Starved of fuel posted by Erik Fellenz on September 02, 2007 at 10:02:06:
Hi Eric, when the 384 stops disconnect the fuel line at the inlet to the fuel lift pump on the right side of the engine block and catch the fuel in a clean bucket. If the fuel dosen't flow the full of the pipe then the problem is between the tank and the fuel lift pump. If there is good flow then the problem is between lift pump and injection pump. My brother had a similar problem with his 684, it would die down under heavy load sometimes stop. If you blew compressed air from fuel filter line back to fuel tank it would run great for a while. Turned out there was a dead lady bug floating around in the tank and every once in a while in would get sucked into the fuel outlet.
Good luck
JimB
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
