Re: Farmall M Low Oil Pressure
Posted by Andy Motteberg on September 02, 2007 at 19:19:46 from (4.143.217.30):
In Reply to: Farmall M Low Oil Pressure posted by tractor man on September 02, 2007 at 15:20:43:
Use high quality engine oil. Check the oil pan and clean it and clean out the screen. Clean out the oil filter body and put in a new filter. While the pan is off, make sure there are no cracked or broken oil lines. If this does not work, try a different oil gauge, if not the gauge, it might be your oil pump or bearings.
