Re: h will not turn over
Posted by El Toro on September 03, 2007 at 04:17:43 from (64.12.116.73):
In Reply to: h will not turn over posted by corey robbins on September 02, 2007 at 18:07:17:
The pistons may be stuck from rust in the sleeves
I would pour more ATF into the cylinders and let it soak. If none of the suggestions on here free it up you may need to pull the head and oil pan and loosen all the bearing caps. Then remove one of the rod caps and use a piece of 2X2 oak and a hammer to tap on the rod to drive it out. Hal
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
