h will not turn over
Posted by corey robbins on September 02, 2007 at 18:07:17 from (24.23.126.183):
I am going to look at an 1947 H this week. The owner stated that it ran just fine before he parked it for a few weeks as he went on vacation. HE said as he tried to start it after his vacation that it would not even turn over. He thought that it might be the battery at first then realized that the battery was o.k. He then tried to turn it over by hand and said that he could barely get it to move. After talking to his neighbers he said that he was told that some water probably got down into the engine and corroded the cylinders. After removing the spark plugs it still would not turn over upon hand cranking. The owner upon suggestion poured about a shot glass of transmission fluid into each cylinder in hopes to free up the cylinders. Currently as of this writing this is where were at.Does this sound very possible that the cylinders could corrode that quickly. Or is there somewhere else to possibly suspect. Again the owner said it ran fine and did not blow any oil out of the exhaust prior to the three weeks it was parked.
