Posted by Doug N on September 03, 2007 at 11:29:50 from (205.188.116.73):
Hi guys. I'm unable to get the pressure at the inj pump above 40 psi on the MD. I even stretched the spring a little, it just goes back to normal. I even tried putting a washer or two in it, nothing. It sometimes goes up to about 50, but goes back down then. It doesn't smoke one bit.
Is the lift pump the problem? If so, how do I fix it?
I was told it should normaly have about 60 pounds. Is this right?
I know that inj pump timing would make it not smoke, but I don't have much pressure. Once I get the pressure it needs, then I'll mess with the timing. Thanks, Doug N
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
