Re: MD injector pump
Posted by Doc Larry on September 04, 2007 at 05:33:53 from (216.146.101.227):
In Reply to: MD injector pump posted by Doug N on September 03, 2007 at 11:29:50:
Doug,
The transfer or lift pump supplies fuel at low presssure to a master plunger that delivers fuel at much higher pressure to the injectors. What you're describing sounds much more like a problem on the high pressure side, or possibly a timing issue as you mentioned. You definitely should get some smoke under load. I think the timing procedure is given in the owner's manual if you have one. If not, a fairly detailed explanation is on either this site or the Red Power site if you do a search of the archives. Sorry I can't remember which.
Assuming you've done all the filters and checked out the scavenging valve, you may end up having to get the pump checked out. I got lucky and found a good used one, cheap, after buying two that were worn out.
Larry
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
