Re: Condensor farmall b
Posted by Janicholson on September 03, 2007 at 14:48:32 from (66.173.50.166):
In Reply to: Condensor farmall b posted by jeff lane on September 03, 2007 at 13:39:27:
If it reads no resistance when first hooked up to a regular meter style Ohm meter, when turned either way it is toast. If it reads infinite resistance hooked either way it is toast. It should (when first attached) read a few ohms then taper to almost infinite ohms. This is the battery in the ohm meter charging the capacitor (that is what it is). This really does not dynamically check the breakdown voltage, or other higher frequency response of the condenser, but it can allow you to toss an open, or shorted one. A condenser checker is not a home product, and is rare because they are easier to replace than check. (condensers do go bad, but are the most over replaced for no reason element in the ign system) JimN
