Posted by El Toro on September 03, 2007 at 18:27:36 from (205.188.116.73):
In Reply to: Re: battery ? posted by jeeper on September 03, 2007 at 17:00:43:
With the engine at 1/2 throttle or better you should be getting 7.25 volts at the battery. You should have around 6.5 volts without the engine running and the generator & regulator should be putting out 7.25 volts or close to that after you start using the tractor. Check the battery elecrolyte in each battery cell and compare the readings. It should be in the 1.250 range or better. The readings should be close to one another too. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
