Re: Replacing the T/A
Posted by Hayfarmer on September 03, 2007 at 21:04:03 from (66.243.235.184):
In Reply to: Replacing the T/A posted by Devon on September 03, 2007 at 19:25:40:
I did one on my SMTA a few years back and believe it is similar. As mentioned, get a repair manuel, either blue ribbon or IT, preferably both. A parts book helps also. There are some bolts that are hard to find without the manuel. Cost will vary depending upon what you need to do. I was able to get by with rebult ramp and rollers, my ta clutch plate and preseure plate were ok, You may want to replace your tractor clutch while you got ti split. I built some split stands to hold the front like the ones shown in IT manuel. I had one for the rear that was ok when only the transmission housing was on it but a bit weak when I hung ta tube back on. I used a tractor loader to take center tube out. The long line up bolts really help, seems like the rear ones were 5/8 and front are 3/4 but can't remember for sure. If you are mechanically inclined you can do it.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
