130 Hydraulic pump
Posted by chad504 on September 04, 2007 at 08:26:45 from (208.252.131.50):
My hydraulic pump on my 130 may be too far gone. I have it off, housing looks great, however the drive gear and shaft are worn badly, inside. Looks like the nut that holds on the drive gear came loose and the key began to wobble, for a long time. the drive shaft is worn, and looks off center, and the gear is just as bad. Can I replace those two pieces? it's a pesco pump. Also, will a pump from a super a/c/340 fit?
