Re: Oil and Water DO Mix
Posted by Doc Larry on September 04, 2007 at 17:45:30 from (216.146.101.227):
In Reply to: Oil and Water DO Mix posted by Mr. Dan on September 04, 2007 at 09:13:52:
You really do want to get the water out ASAP because water will collect between the bearing balls or rollers and the seats, and leave small rust pits that can eventually take out your bearings. I think I would drain completely, refill, run till it is good and hot, then drain and refill again. You aren't going to get any sludge out, but you'll get most of the water out.
Larry
