340 IH utility Distributor
Posted by Kevin Moschenrose on September 04, 2007 at 20:50:45 from (63.237.60.16):
I am postting this for a friend. He has a 340 utility gas tractor that has a fork lift mounted to it that drives in reverse. Today I was using it and the points in the distributor broke at the spring. I replaced with new ones and now it doesn't want to keep in time. I set it and it seems to act as though it jumps time and starts to miss and back fire. We reset it again and it does run okay a little than starts to run rough and backfires again. I am thinking the distributor has went bad and or is missing a tooth or shorting out inside? I am a Minneapolis Moline man and haven't seen anything like this before. If it is a bad distributor what other models will interchange with this? Thanks in advance.
