Re: 340 IH utility Distributor
Posted by Hugh MacKay on September 05, 2007 at 03:06:15 from (216.208.58.118):
In Reply to: 340 IH utility Distributor posted by Kevin Moschenrose on September 04, 2007 at 20:50:45:
Kevin: Sounds as though the distributor drive gears are starting to strip, and it's slipping a few teeth ocasionally. Early on they will may go a few revolutions to a few min. That wont last long until it stops turning completely. Gently try turning the rotor you should feel it slip. Probably one spot on gears worse than rest. Pull the distributor out, condition of teeth will soon tell you if that is the problem.
Since it is a C-135 engine, the distributor drive gears from any letter series that had distributor, 00 series, 30-50 series and just about any 4 cylinder IH gas engine will be the same. Not sure about the 4 cylinder engines after mid 60s, however it probably never changed. I know the C-123 in the 140 never changed.
Today's Featured Article - Memories of a Field Service Engineer - by Brian Dye. I worked for one of the largest Ford tractor dealerships in England as a trouble-shooter on tractor engines, hydraulics and combine harvesters from 1963 to 1972. In 1972 I became a dealer manager and finally left the dealer net in 1975 to run my own electronic design and manufacturing company called BHE after the old 16th century Inn where we are now based. We specialize in agricultural electronics working in the past for Claas, Grimme, Standens and Reekie on combines, potato and sugar beet har ... [Read Article]
