Before you tear your tractor to pieces, check the simple stuff first. If the timing gears were the problem, you would not be getting a spark, let alone a spark that's "on time." The crank gear drives the cam gear, and the cam gear drives the distributor, so if the distributor is turning, the cam is turning.
Sure, there is gas in the tank, but is it getting to the carburetor? If it's getting TO the carburetor, is it getting THROUGH the carburetor?
Have you pulled the oil cup off the air cleaner?
Have you pulled the air hose off the carburetor intake? Does it have good suction when you crank the engine?
You can pull the valve cover off easily. See if the valves are moving.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
