Re: Getting close on the 22-36...questions
Posted by randy hall on September 05, 2007 at 11:36:04 from (209.143.0.64):
In Reply to: Getting close on the 22-36...questions posted by Josh in SD on September 05, 2007 at 11:05:04:
you will just want to run the tractor on gas. you will have many less problems. the previous owner might have put gas pistons in for more power. i would use 140 weight gear oil. model t fords use 600 weight oil in the rear end.
