Re: Farmall B - Whatzat noise?
Posted by ScottyHOMEy on September 05, 2007 at 16:02:25 from (71.241.196.242):
In Reply to: Farmall B - Whatzat noise? posted by Dave H (MI) on September 05, 2007 at 15:11:29:
M'self, I lose the rumble and listen to the howl of the fan. ;8^) I remember on Grandpa's farm, that's what you heard from the house was the fan, not the exhaust.
My guess is that it's just wear on the gear that you were in. If the tractor spent a lot of time cultivating, for instance, in 2nd, that gear is worn more than first or third and will be noisier, especially on the coast side. No harm, there's in all likelihood plenty of tooth left on the gear, just it will be noisier than the others. It's just the gear that it got worked on the most.
I wouldn't worry. Chalk it up to the tractor5's personality.
