Re: Got another funky problem with my l'il put-putter 100...
Posted by Patrick Martin on September 05, 2007 at 19:45:49 from (64.154.26.250):
In Reply to: Got another funky problem with my l'il put-putter 100.....:( posted by Patrick Martin on August 30, 2007 at 20:52:49:
Hey guys I'm back and I just gotta say thank you so very much for the help/replies!!!!!!! third party imagethird party imagethird party image
I spent some time with my grandfather this past week off and just got back. Here's what I found out today....
My temperature gauge is BROKEN! I must have somehow pinched the thermocouple lead while removing the thermocoupule itself. I checked the gauge today and it is actually stuck in between the 100-110 temp mark. It is quite possible this is a source of my worry here.
I'm dropping the oil pan tommorrow and removing some shims. that ought to fix the OP problem.
I tightened the belt but still need to scoot the alternator back some. Hugh, I'm gonna email you about those plans. Thanks!third party image
George, I will be removing the head of the Touch Control unit tommorrow to check it out. I will see how dirty it is and will clean it thouroughly. Hopefully I will find it's just dirty, if not I guess I will start replacing O-rings again!third party image
I just picked up a flywheel cover AND a sickle mower for my M (will post pics in a bit) this past week. Now I have a timing pointer and will be timing it to specs soon!!!!
BIG THANKS AGAIN DEAR TRACTOR BRETHEREN! third party imagethird party image
