Re: Can't get timing right
Posted by old on September 06, 2007 at 14:46:40 from (4.245.1.134):
In Reply to: Re: Can't get timing right posted by IndianaRed on September 06, 2007 at 12:25:22:
If its a true 12 volt coil it will say on the out side of it not resister needed. If its a 6 volt coil made for 12 volts it will say external resister needed. Yep what you did was got it on TDC on the exhaust stroke instead of compression and that will throw you off 180. Don't feel bad most of us have BTDT at some point in time
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
